October 7, 2002, 05:03 |
sources
Hello CFX users! Could anyone please give me some examples or explanation about source specifications in multiphase flow? There are no source specifications in Tutorial 15 and 16 in CFX 5.5.1. However, according to the governing equations sources are very common. I am really puzzled. Looking forward to your comments. Thanks.
Best regards David |
October 7, 2002, 09:20 |
Re: sources
If you transform one phase into another (mass source and sink will exist) for example... That is quite straighforward to implement in CFX-5 using cel and ub-domains.
October 7, 2002, 23:28 |
Re: sources
Thanks. What does "ub-domains" and "cel" mean ? Does it mean "sub-domains"?
Regards David |
October 7, 2002, 23:30 |
Re: sources
Sorry, another question. How to generate mesh for a very long pipe with narrow diameter, for example, with 2 metres length and a 0.02 metres width?
October 7, 2002, 23:49 |
Re: sources
A Hex mesh would be best for this pipe. You can switch the meshing mode to Patran Meshing from the Preferences menu in CFX-Build to allow Hex meshing. Your support rep should be able to tell you more about using this feature. Mike
October 8, 2002, 01:16 |
Re: sources
Thanks Mike. First I want to try Patran method.
Modeling the power sources | saisanthoshm88 | CFX | 2 | April 6, 2011 18:46 |
Add total mass using sources to multi component fluids | mullenc525 | CFX | 1 | February 5, 2011 04:56 |
"Mobile" entities: cell zones, sources, etc... | r08n | OpenFOAM Programming & Development | 0 | March 26, 2010 12:23 |
Bacteria sources in simulation | Eric | Main CFD Forum | 1 | June 17, 2008 18:49 |
Sources for multiphase multicomponent reaction sys | Liwau | CFX | 3 | May 20, 2004 23:08 |
