File type of outfile
Old   November 4, 2002, 11:05
Default File type of outfile
David
Hello everybody, I opened my outfile in wordpad, now all outfiles in my computer have been automatically transfered to wordpad, now my solver doesn't work. So could anyone please what I should do? What's the original type of outfile, so I can change it back. Thanks.
David
Old   November 4, 2002, 13:00
Default Re: File type of outfile
Holidays
(I guess you are talking about the oputput file (ascii))
This is not related as far as I can see! On your PC use "Open with..." and chose the text file tool you like.
Old   November 4, 2002, 19:49
rambol
The type of outfile will not influence the solver.I also open it with wordpad. there maybe exist other reasons
Old   November 4, 2002, 22:34
David
Thanks. This morning I tried again with only water in my geometry, I got a converged solution, and I found the outfile is still in wordpat format. However when I tried again with my two phase flow, the solver didn't work again. Should I reinstall CFX again?
Regards David
Old   November 4, 2002, 23:28
David
Thans. This morning I deleted all outfiles, then I run only with water in my geometry. I got a converged solution. I found the outfile is still in the format of wordpad. After this, I tried my two phase flow, the solver didn't work again. Then I delete the outfiles once more, and tried the two phase flow one more time. Now it works again. So it should be related to the format of outfile. I am afraid even if I reinstall CFX again, the outfiles will be automatically changed to wordpat. So I want to return the format of outfile to its original form. But I don't know how to do it. Could you please check your outfile format? Thanks.
David
Old   November 5, 2002, 16:06
Astrid
Dear David,
I have all file with the extension *.out linked to notepad. Works all the time.... in WinNT and Win2000.
Astrid
Old   November 6, 2002, 04:37
Drona
Hi David,
When you want to open a file the Windows doesn't recognise, it asks you to specify what programme you want the file to open with. In that "Open with" dialogue box, there is an option at the bottom, "Always use this program to open these files". Probably you checked that box, and it always uses that program. You should uncheck that before opening the files.
And, yes, the out file format shouldn't affect the soluction though. Only the BC and solution files should be in correct format.
Cheers
Drona
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 07:32
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
