What this meshing error message imply for?
Old   November 4, 2002, 22:33
Default What this meshing error message imply for?
line
When I try to mesh my geometry, I got the following error message. Can you tell me what this imply for?
Thanks Jim
---------------------------------------------------- Giving up! please check the file name and try again!
Old   November 4, 2002, 22:37
Default Re: What this meshing error message imply for?
line
Ar. I fix the problem by saving the db file into other name. But this time I got Warning: coincident points and FATAL ERROR wrong connectivity during surface meshing! topology problem again?
line
Old   November 5, 2002, 02:24
line
The problem I target on is a very simple things, but I guess some trick have to be used before it work. It is a concentric circular domain with 10m and 20m diameter. I use the B-rep for the inside column which is 5m longer than the surrounding ring. The surrounding ring is a Solid. So I treat it as 2 bounded domain and the self intersecting mesh is come one on the interface between this two bounded solid. Then I try to modify the B-rep solid so that it use the inner side of the surrounding ring as one of it's contruction face. Problem still occur. I need to take some rest. It is only for fun for trying the domain and sub-domain usage.
line
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
