PCO simulation
Old   December 8, 2002, 23:52
Default PCO simulation
line
Can you give me some suggestion to simulate the PCO process. PCO stand for Photo-Catalytic Oxidation.
I want to use the TiO2 (Titanium Dioxide) with UV lamp to treat the VOC. Did CFX have some kind of predefined chemical reaction to handle this problem? If not, is there an alternate method exist?
Thanks Jim
Old   December 9, 2002, 02:14
Default Re: PCO simulation
Holidays
If you know the reactions you can code them using the REACTIONS file as an example.
To define the UV effects I guess you could define geographically (in space) the effect (luminosity?) it has and therefore define the impact it has on your reaction rate (which you could define or tame via an expression function of luminosity in the Expression editor). I have seen a paper in CFX Update relating to the UV treatment of water but I think it was more a matter of UV intensity in water than driving a chemical reaction per se; yet the principle is there.
If you do not know the reactions, you could always drive the transfer process via source/sink terms; but I would tend to prefer the first approach if I could.
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Axial fan simulation in UG/NX 7.5 fan123 Main CFD Forum 2 April 23, 2011 08:22
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
