December 27, 2002, 02:10 |
particle trajectory
I have the CFX simulated steady wind field in a tube. And would like to have some particle trajectory plot based on this steady wind field. Is CFX Post is capable to do that? I have produce a very nice picture for streamline but cannot find the option for particle trajectory. Should I dump out the result and write my own code to do that? Thanks Jim |
December 31, 2002, 00:19 |
Re: particle trajectory
choose the option "track file", and then choose the *.trk file as the track file.
January 2, 2003, 08:21 |
Jim, are you using CFX5 of CFX4 ? at present there is no capability in CFX5.5.1 for particle tracking. CFX5.6 which the beta release should be out shortly will have particle tracking embedded into it. Version 4 of the software does include particle tracking, however I'm not sure if you can just run the particle tracking by itself (you should be able to but I'm not 100%), so you may need to do a restart on your existing run and start the particle tracking. The files that the particle tracking creates can then be read into post as a polyline. This can be tedious to read in so I'd reccomend setting up a little perl script session file to do this. Good luck Bob
January 2, 2003, 13:20 |
Bob,
I am using CFX5.5. Thanks for your advice. Jim |
January 3, 2003, 08:16 |
Try talking with you support person at CFX, they will advise you as to you best next step ie wait for 5.6 or trying CFX4 ? Bob
Particle Trajectory calculation | yueroo | FLUENT | 2 | July 13, 2009 13:32 |
Plotting Particle Trajectory | rajesh | Main CFD Forum | 0 | May 15, 2009 13:35 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
how to output particle trajectory coordinate data | steven | CFX | 0 | July 13, 2006 17:49 |
Particle Trajectory calculation when particle hit | yueroo | FLUENT | 2 | February 28, 2001 04:26 |
