January 13, 2003, 07:18 |
parametrization
I have to optimize a wing profile. How can I set up the variables and functions (like sin cos tang) ? Anyone have an example of session?
January 13, 2003, 08:52 |
Re: parametrization
Hi Stex!
You can use the tool -> expression editor to define you own function or to use standard function (sin,cos, ... ). Or you write it in CEL in your CCL-definition file (Use tools -> OS Command Line and a text editor) |
January 15, 2003, 11:59 |
Re: parametrization
how can I create a Costant for example alfa=0.145 and then create a point which has x=30* cos(alfa); y=0; z=0; from command line in cfx5.5-build ?
thanks |
January 16, 2003, 09:41 |
Re: parametrization
Hi! What exactly do you mean? Do you want to create a geometry or a simulation variable (like velocity or concentration). I thought about the second one.
Bye! |
January 17, 2003, 07:41 |
Re: parametrization
I want to create a Geometry, Roman, beginnig from the creation of parametrized points!!
January 17, 2003, 07:51 |
Re: parametrization
Hi Stex! Sorry, but I create my geometry only in CFX build (common methode) and never have used the parametrisation. So I don't have experience with this too. I thing Holidays can help you to do this.
Bye, Roman |
January 13, 2003, 12:40 |
Re: parametrization
Hi Stex,
I think you want to set this up in PCL (PatranCommandLanguage) so that you can adjust your geometry? Am I right? In this case give a look at thye Patran/Nastran language (it is briefly described in CFX course notes) and use the Perl provided within CFX-5 to run loops of "optimisation" based on the results you post-process in Post that feed algorithms that will drive the writing-up of adjusted parameters in the session file for Build-5 (all in Perl). |
CAD interface, parametrization | AranyiPatricia | ANSYS | 4 | August 23, 2010 08:42 |
parsec and sobieczky airfoil parametrization | morteza08 | Main CFD Forum | 0 | July 9, 2010 15:26 |
Catia - parametrization | stex | Siemens | 1 | June 2, 2003 08:07 |
Catia - Parametrization | stex | CFX | 0 | May 27, 2003 03:47 |
Parametrization | Stex | CFX | 10 | January 21, 2003 06:59 |
