mesh quality
Old   January 13, 2003, 11:46
Default mesh quality
sxf
Does anybody have some idea of how to check the mesh quality for CFX. Thanks in advance.
sxf
Old   January 13, 2003, 14:23
Default Re: mesh quality
John K
There a number of options in CFX-Post such as edge length ratio, volume ratio, face angle etc.
Old   January 15, 2003, 19:24
Default Element Volume Ratio
boji
I found the range of Element Volume Ratio of my mesh is between 1 to 40, and in a certain Plane, the area EVR>5 is up to 30%. Connectivity Number is between 2 and 64. (I also found in example 2, staticmixer_finemesh, has a similar situation. While according to "tool_menu.pdf" in manual, page 140, EVR higher than 5 may cause problem. I was confused.)
Sometimes I experienced problems with the flow field and convergence, is it a possible reason? How do you think the importance of EVR, CN and other mesh parameters? How can I improve this?
Waiting for your suggestions and opnions.
Old   January 17, 2003, 17:25
Default Re: Element Volume Ratio
boji
can anyone give me some hints here?
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 07:38
[snappyHexMesh] mesh quality control and fix tachyon_me OpenFOAM Meshing & Mesh Conversion 0 October 6, 2009 12:48
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
