March 28, 2003, 13:27 |
Wind Tunnel walls with perforated section
Hi, I have to model a fluid flow around a 3D missile in a wind tunnel. But some part of the tunnel wall is made up of preforated wall. Is it possible to model perforated part of the wall using CFX? If yes, which boundary condition must be used?
March 31, 2003, 17:58 |
Re: Wind Tunnel walls with perforated section
You have to define a subdomain in which a resistance is present (lineair or quadratic). Then you have to define the outlets a little further downstream, the thickness of the perforated wall to be precise.
Pascale |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
how to consider perforated wind tunnel wall in CFD simulation | littlelz | CFX | 4 | June 11, 2009 05:51 |
Surface roughness setting for a model in wind tunnel test section | Sharon | CFX | 12 | March 31, 2009 13:09 |
Wind Tunnel Testing | Francesco Nicolosi | Main CFD Forum | 0 | November 25, 2008 12:55 |
Simulating a Göttingen type wind tunnel in FLUENT | Chris | FLUENT | 3 | December 4, 2006 17:33 |
