Dual temperature boundary condition
Old   June 3, 2003, 04:46
Default Dual temperature boundary condition
Louwrens
I need to specify an atmospheric boundary, where the specified temperature is dependent on the flow direction. For flow into the domain, the specified temperature should be the ambient atmospheric value, but for flow out of the domain I want to specify a zero-gradient condition. I know CEL would probably be the way to do this, but how? The problem basically is how to "detect" whether the flow in into or out of the domain at the boundary, and if out, how do I specify a zero gradient? I'm using CFX 5.5.1
Louwrens
Old   June 3, 2003, 21:58
Default Re: Dual temperature boundary condition
Robin
Hi Louwrens,
This is what you get when you use an opening. If flow is coming into the domain, the temperature is whatever you specified; if flow is exiting the domain, the temperature is determined by the upstream condition (zero gradient at outlet).
Regards, Robin
Old   June 4, 2003, 03:58
Louwrens
Oh the bliss...
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Temperature dependant mixed Boundary condition argonaut OpenFOAM Pre-Processing 2 February 15, 2011 11:02
How to apply the temperature boundary condition on the outside of the mould? alefem FLOW-3D 5 May 25, 2010 05:32
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 10:06
boundary condition : temperature J.D.Yoon FLUENT 1 August 29, 2000 04:08
