transient diffusion convection
Old   June 26, 2003, 09:34
Default transient diffusion convection
Volker Göke
Hi CFX 5.6 world! I've modelled the following problem successfully for the stationary case but have no idea how to work in some transient modifications:
Object: Rectangular Parallelepiped (20* 20* 50 mm(height)) with a capillary tube (right-angled to one side wall) some millimeters above the bottom.
Fluid domain - so far only one,
Fluid model : variable mole fraction, isotherm
2 Inlets (Bottom, Top) 1 Outlet (Capillary tube)
The composition at the two inlets differs (otherwise no diffusion due to concentration gradient - okay?!)
Result:A relative sharp z-gradient on the level of the capillary tube. Also transport occurs in x and y direction.
Now the real problem: The bottom inlet isn't usefull anymore. But I would like to start the simulation with an initial concentration distribution (only depending on the z-coordinate). A step function (any height from the bottom th the top should be possible) would be enough for the first guess. How can I implement this? - even sleeping on the manual wasn't successful!
Thanks for all helpful hints!
Volker
Old   June 26, 2003, 16:20
Default Re: transient diffusion convection
Phil
Step functions are easy with CEL. The bump tutorial has an example of using a step function to initialize variables (in that case, it is used to initialize volume fraction for a free surface calculation).
Mass Diffusion: Transient and Steady State BC rval CFX 3 November 19, 2008 00:52
Convection, diffusion and reaction Joao CFX 0 October 25, 2008 20:19
diffusion effect opposite to convection hasan karabay Siemens 0 December 5, 2006 06:59
transient simulation: natural convection problem? Basics CFX 3 September 25, 2002 09:42
