tascflow - impeller volute interface
Old   August 21, 2003, 13:06
Default tascflow - impeller volute interface
abaqus
I am planning to simulate impeller volute together in Tascflow. Frozen rotor interface applied between impeller outlet and volute inlet. But there should not be any solid surface at interface. In my model vane thickness is coming at the interface. How to deal with it.
Can I simulate impeller and volute separately. In this case impeller can be solved by simulating one passage between the vanes. And after impleller solution how to put it around volute inlet.
Send suggestions....
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Volute outlet flow into impeller inlet Anthony_impeller CFX 4 December 13, 2011 16:17
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
