memory allocation
Old   October 5, 2003, 00:37
Default memory allocation
strudl
Hello Can anyone care to explain this to me please Storage allocation failed Number of words requested = 62033932
No. bytes/word = 4
Array = n_bf3 Current memory allocated = 1465479948 bytes Maximum memory allocated = 1586840100 bytes ================================================== ==============================
The mesh generation program was unable to allocate enough memory. That is memory that can be grabbed by a 'malloc' statement. In general this will be a machine dependent combination of available real memory and swap space. If in doubt, contact your systems administrator.
Old   October 5, 2003, 10:26
Default Re: memory allocation
Eldoret
Hi Studtl, From your earlier postings, it appears to me that the problem is just memory. You said "The rule of thumb is: 1 million Mesh = 1 Gb of ram". From my little experience with a wide range of problems, I feel very reluctant to subscribe to this school of thought. Without an adequate knowledge of the numerics (double or single precision, grid, solvers etc) and physics (flow regimn, phases or components etc) of ones problem, it is difficult to tell!!.
The first question of interest; do you really have enough memory? If so, does you machine support that kind of memory?
I used to get a message of License manager problem....., this was a HOAX as I later found out when i increased the RAM.
regards Eldoret
about numeca harmonic method Memory allocation failed uqzcpo Fidelity CFD 2 October 7, 2011 22:10
Memory allocation problem Ammar Abdilghanie FLUENT 5 February 19, 2007 18:15
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
Memory allocation problem shhe CFX 4 January 6, 2004 23:00
Dynamical memory allocation for multiblock? peter.zhao Main CFD Forum 2 May 20, 2002 04:58
