Linearisation of governing equations
Old   November 13, 2003, 12:03
Default Linearisation of governing equations
Märta-Karin Brandt
Hi!
Does anybody know how the governing equations are linearised in CFX-5.6?
Regards, Märta-Karin
Old   November 13, 2003, 16:25
Default Re: Linearisation of governing equations
Hi Märta,
It's all in the documentation for the codes. If you are using CFX5 have a look in the solver theory manual. If you are using CFX4 have a look in the solver manual.
There are also a number of good text books on the basics of CFD. Have a look at the books section of CFD-online for a selection.
Regards, Glenn
Old   November 14, 2003, 05:32
Märta-Karin Brandt
Hi Glenn,
Thanks for your advice. I've looked in the solver theory manual but I can only find information about how the equations are discretised, do you know if there is some other useful chapter I may have missed? I've also searched in CFD books, but it seems to me as there are several ways to linearise and I would like to know which method CFX-5 uses. In chapter Coupled Solver Theory, it says "coefficient iteration", I would like to know which coefficients and what the iteration process looks like. Do you have any reference to anything you think I should read?
Many thanks, Märta-Karin
Old   November 14, 2003, 09:33
BAK_FLOW
Hello Marta,
you might want to try the Theory documentation for TASCflow. Although for the structured code and slightly different discretzation (skew schemes rather than gradient reconstruction) it is a very detailed reference. There also are detailed references to published papers which have even more of the details.
Regards,
Bak_Flow
governing equations in air water flow ghazali Main CFD Forum 1 March 8, 2015 22:47
governing equations kasool FLUENT 0 July 6, 2011 04:20
CFD governing equations m.gos Main CFD Forum 0 April 30, 2011 14:21
Governing equations for non-linear wave motion Dr.K.Thiruvenkatasamy Main CFD Forum 1 June 1, 2006 06:33
1D governing equations Andrei Chernousov Main CFD Forum 5 July 13, 1999 15:06
