November 22, 2003, 08:30 |
How to convert .dwg into .igs files?
Hi all! Could somebody tell me how to convert Autocad geometry .dwg files into .igs files to be imported by CFX. Does Autocad have an option to do it or an additional soft is necessary?. Many thanks. Juan.
November 24, 2003, 00:12 |
Re: How to convert .dwg into .igs files?
This is the way I know. If u have mechdesktop, open the *.dwg file in it and export as IGES file.
cheers BK |
November 24, 2003, 11:39 |
You can not get *.iges out of Autocad, one way is to use Microstation to read your Autocad file and then export it as .iges, the other option which I use is Cadfix, you export ACIS out of Autocad, and then Cadfix to get iges. Either way, you need another program to get it out
November 25, 2003, 06:45 |
Many thanks both Buyung and Ogbeni, I'll try these options. My problem seems to be solved.
Juan |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
