compressible gas problem
Old   December 25, 2003, 22:42
Default compressible gas problem
hx
Hello everyone,
I am analysing a chemical reactor. I am confused with compressible ,incompressible and weakly compressible gas, and in which occation they are used. My simlation is for high pressure.I do not know how to set reference pressure, their relation with absolute pressure and how to use it for compressible incompressible and weakly compressible gas. I am in urgent need for your help. Thanks a lot for your help.
Best regards, Hx
Old   January 5, 2004, 02:00
Default Re: compressible gas problem
matej
Hi Hx,
according to the terms you use, you are user of CFX 4. Is that right? It is well described in the manual. The fully compressible flow is flow, where the density is function of temp and pressure. which is normal compressibility. For easier calculation of slow (Ma<0.3) combustion flows mainly weakly compressible version is available, where density is function of temperature only. p_abs = p_ref + p, where p is pressure actually calculated.
does it help?
Matej
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
gas through porous media problem jiguozhao CFX 2 February 25, 2011 02:14
COG(Coke Oven Gas) Combustion Problem in "W" Type Radiant Tube sdlafkj Main CFD Forum 2 February 19, 2011 01:54
Need help with a compressible flow problem JP FLUENT 0 August 19, 2008 13:11
Convergence problem for compressible flow Saad Main CFD Forum 2 June 5, 2005 15:24
