CFX, 2 dimensional flow
Old   December 21, 2003, 18:12
Default CFX, 2 dimensional flow
Beno
Hi!
I have an assignment to simulate flow in two dimensions. Is that possible with CFX 5.5.1, and how do you do it?
Thx!
Old   December 22, 2003, 05:18
Default Re: CFX, 2 dimensional flow
Bob
Hi Beno, Yes it is possible, but it depends upon your geometry as to how best to approach the problem. If the geometry is nice and simple (assuming you do not have lots of meshing experience), I'd use a structured mesh which can easily be defined as 1 cell deep. On the boundaries of the 3rd dimension you have to specify symetry planes. Now if your geometry is more complex then you may well have to use the unstructured mesher. But that will give you 3D cells. So to get a truely 2D mesh you need to create a 3D mesh, define GGI boundaries rather than a symetry planes on your 3rd dimension, and then invoke an enviroment variable to tell the solver to extrude one of the GGI surface mesh's through to the other boundary.
Unfortunately, I can't remember which enviroment variable it is, plus I'm not 100% sure that the GGI is the correct definition, it may be a periodic pair ? sorry. But the long and short of it is that you can do 2D runs. May be some one else can clarify the last points for you. Have you done a search on the CFX comunity site, as I'm sure there is help there either in an FAQ or just a regular querrie.
Good Luck
Bob
Old   December 22, 2003, 08:43
Bob
Hi Beno, the enviroment variable is: CFX5_2D_MESH set this to be TRUE.
To return to 3D meshing you will need to rempove this variable. The boundary condition you need to apply is a periodic pair. This should then create a 2D mesh when the def file is created.
Hope this is a little more clear now ? Bob
Old   December 25, 2003, 02:01
Jeff
If it's truely 2D (no flow in the third direction) you don't need the GGI. Simply use the symmetry planes.
If there's rotational flow (2D axysymmetric) then you can still do this without a GGI. Use the paver option for meshing and pave quads over your 2D face. Then sweep these elements 1 cell thick in the Z direction. This gives hexes which match up on the high and low Z faces and can be set as symmetry planes.
Jeff
Old   December 30, 2003, 16:00
Ron
CFX is point based. Aren't two cells required for the thickness? (i.e. points in the middle)
With one cell thick, there are only points on the symmetry planes.
Not sure.
-Ron
Old   January 4, 2004, 17:26
Hi Ron,
The 2D simulations work fine with just one cell in the thickness. Done it many times.
Glenn
Old   January 5, 2004, 10:29
Ron
Thanks Glenn!
Flow Analysis tilting Pad thrust bearing using CFX julien CFX 5 April 9, 2014 08:38
[HELP] Slip flow boundary condtion in CFX jeffwmb CFX 20 March 13, 2013 16:21
Ansys 11.0 CFX - solving electric potentials and multiphase flow cfd_multiphyiscs CFX 2 March 10, 2010 13:43
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 07:08
demo free flow blunt body in cfx ansys 11 jan CFX 1 July 31, 2007 19:44
