January 28, 2004, 04:58 |
monitorpoint in 5.6
hi,
Does anyone know how should I define monitor points in 5.6? according to the manual the mon.point definition window should look like this but in my Pre it looks like that . The boxes for the point coordinates are dead - impossible to enter values Is it possible to define mon. point via editing the def file (in the solver man. or exporting the ccl and editing it)? Should I ask for some kind of new patch? I've already installed several patches, including Pre patch 200307081045 |
January 28, 2004, 11:45 |
Re: monitorpoint in 5.6
You can add them at runtime from the command line as well.. The section of CCL you require follows:
FLOW: OUTPUT CONTROL: MONITOR OBJECTS: MONITOR POINT: joe Option = Cartesian Coordinates Domain Name = <your domain> Coord Frame = Coord 0 X = ??? [m] Y = ??? [m] Z = ??? [m] Output Variables List = Velocity, Temperature END END END END For multiple monitor point locations, just copy the MONITOR POINT section, rename and modify as needed.. You can start the run as: cfx5solve -def your_file.def -ccl file_with_ccl_above or cfx5cmds -def your_file.def -text your_file.ccl -read add the CCL section above to your_file.ccl and remerge (using -write this time).. And run it as usual from the Solver Manager.. I hope this helps, Juan Carlos |
January 28, 2004, 11:55 |
Thanks very much. This will be very useful. bogesz
January 29, 2004, 07:22 |
Hi I know more easy manner. You have to switch on expression and write something (i.e. bleble) and then close window. At next opening window you have active boxes. good luck
January 29, 2004, 07:38 |
Thanks, it's working! bog.
January 29, 2004, 16:25 |
This may be a bug of CFX5.6 because I had the same problem. You can just add a new monitorpoint, then delete the old one. Everything will be ok.
CFX 5.6 mesh build | shhe | CFX | 1 | February 13, 2004 04:27 |
CFX 5.6 - on XP | cameron | CFX | 1 | January 26, 2004 12:27 |
CFX build 5.6 | Richard | CFX | 8 | September 10, 2003 12:20 |
CFX 5.5 and 5.6 | Peter | CFX | 1 | August 22, 2003 08:50 |
Modelling thin surfaces in 5.6 | Louwrens | CFX | 0 | August 16, 2003 10:47 |
