Mesh Extrusion in ICEM4CFX
Old   February 25, 2004, 09:53
Default Mesh Extrusion in ICEM4CFX
sacha
Hi all, I tried to use the mesh extrusion available in ICEM-4-CFX. I meshed a part of my cylinder using the automatic way and created a part consiting on a face (disc). I then extruded the mesh and it worked fine; BUT when I try to export it in CFX-MESH I got a message saying that my extrusion can not be imported because it is combinaison of elements, faces and nodes.
Any suggestion?
Thanks
Old   February 25, 2004, 11:32
Default Re:CORRECTION: Mesh Extrusion in ICEM4CFX
sacha
Hi all, I tried to use the mesh extrusion available in ICEM-4-CFX. I meshed a part of my cylinder using the automatic way and created a part consiting on a face (disc). I then extruded the mesh and it worked fine; BUT when I try to export it to CFX-PRE I got a message saying that my extrusion can not be imported because it is combinaison of elements, faces and nodes.
Any suggestion?
Thanks
Old   February 25, 2004, 16:13
Hi Sasha,
You have to be careful the volume elements are in a different family to the shell elements. If a family contains both shell and volume elements it gives the error you mention.
You may have to manually change the family of some shell or volume elements to fix this. You can do this by turning all geometry off, then you can select elements and manually change the family selected elements are associated with.
Regards, Glenn
Old   February 26, 2004, 05:07
sacha
It works!! Thank you Glenn!!
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
