2D cavitating hydrofoil
Old   February 26, 2004, 06:02
Default 2D cavitating hydrofoil
Therus
Hello, I'm doing a simulation of a 2D cavitating hydrofoil. The cavitation number "determines" the reference pressure. What I'm curious about is what the normal outlet BC should be. I'm am using Relative static pressure of 0 Pa (advice from a paper). Does anyone here model the outlet in a different way? If yes, then how??
Best regards Therus
Old   February 26, 2004, 11:14
Default Re: 2D cavitating hydrofoil
thammasak
hi Normally we use absolute total pressure as an inflow b.c and mass flow at outlet bc so we can change inflow bc to the critical point that lead to cavitaion occured.
Cavitating model in OF zhaowg OpenFOAM 18 December 25, 2014 15:57
cavitating flow over a hydrofoil Actone-Zero CFX 3 February 3, 2011 17:37
What is the exact Gause pressure at the outlatboundary for cavitating flow. Nur Main CFD Forum 0 June 29, 2009 22:53
Negative value of 3D Hydrofoil. sam FLUENT 1 February 2, 2005 10:51
Hydrofoil Transition Andrew Parker FLUENT 0 August 17, 2001 06:48
