April 14, 2004, 06:33 |
Flotran -distributed resitance
I'm doing a Flotran analysis and I have to model a cooler (for electric machines) with an air filter.The distributed resistance must be specified for the filter and I have the measured (pressure drop) vs (outlet velocity) diagram for the filter.How can I find from that the a and b coefficients for the friction factor f=a*(RE)**(-b)!? (From Darcy-Weisbach equation is possible to find the friction coefficient,but what is the hydraulic diameter and Reynolds-nr. in case of filters?) Has somebody experience using this method of specifying the distributed resistance? Regards, Zoltan |
April 14, 2004, 08:57 |
Re: Flotran -distributed resitance
Trying is the best way. Change the parameter as long as the required pressure loss over the filter element is achieved.
HP MPI warning...Distributed parallel processing | Peter | CFX | 10 | May 14, 2011 06:17 |
Ansys FLOTRAN. Remeshing according velocity vectors or streamlines? | pablo--- | ANSYS | 2 | December 11, 2009 04:35 |
Firewall settings bproc distributed file syntax | mike_jaworski | OpenFOAM | 2 | January 14, 2008 10:46 |
distributed mpich problem | Trevor | CFX | 15 | January 9, 2007 17:08 |
Flotran | Arvind | Main CFD Forum | 0 | May 15, 2002 18:10 |
