July 1, 2018, 10:47 |
CFX solver interpolation
Hi guys,
I used user defined remeshing through junction box routines. CFX solver interrupt the calculation at each time step, then replace the mesh file with new one and interpolate the result of old mesh into the new mesh. which type of interpolation CFX uses. do I have access to change it or not and how? Does interpolation scheme affect results? regards, -Fahd |
July 1, 2018, 18:50 |
Rep Power: 143 |
It is almost certainly linear interpolation. I have not found a reference to justify that but I would imagine higher order interpolation would cause more trouble than it is worth due to unphysical overshoots.
I do not think you have access to change the interpolation done by CFX. If you want to change the way this is done you can write your own initial condition in user fortran and use what ever interpolation scheme you like. Yes, interpolation scheme will affect results. Getting an interpolation scheme which is conservative is challenging. Also getting one which accurately keeps rapid changes in variables is also challenging. Getting a scheme which does both is just about impossible.
August 3, 2018, 01:53 |
Lance
Rep Power: 22 |
The expert parameter
interp second order data = t |
August 3, 2018, 06:25 |
Rep Power: 143 |
I did not know that, thanks!
But be aware that higher order functions are prone to gross overshoots. Caveat emptor!
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
CFX solver doesn't start through Workbench | oj.bulmer | CFX | 3 | June 30, 2012 08:44 |
viewing cfx post while working on cfx solver manager | HMR | CFX | 5 | March 9, 2011 22:33 |
[ICEM] trouble with mesh quality from ICEM in CFX Solver | escher25 | ANSYS Meshing & Geometry | 0 | February 28, 2011 07:38 |
