May 14, 2004, 03:43 |
rms pressure
hi,friends can I use cfx5.6 to extract rms pressure from res file,thanks. regards colins
May 18, 2004, 20:41 |
Re: rms pressure
it depends what sort of simulation you are doing doesn't it. how are you simulating it?
May 24, 2004, 00:51 |
Re: rms pressure
to James: I am doing a steady simulation,now I don't think CFX5 can extract rms results from the res of steady simulation. regards colins
May 24, 2004, 00:59 |
Re: rms pressure
correct
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
RMS P-mass no-convergence for low pressure ration,low rotor speed turbine | Ton | CFX | 3 | November 6, 2010 06:21 |
Setup/monitor points of pressure and force coefficients | siw | CFX | 3 | October 22, 2010 06:07 |
Operating condition in Fluent | MASOUD | FLUENT | 3 | September 16, 2010 17:50 |
Setting pressure and velocity in inlet | Asghari | FLUENT | 5 | September 22, 2006 13:23 |
