June 10, 2004, 13:56 |
how to see the mesh in PRE/POST?
Hi everybody!
I want to know if there is a way to see the mesh in POST or PRE. It's very urgent! Have a nice day, Ioana |
June 10, 2004, 20:28 |
Re: how to see the mesh in PRE/POST?
Hi Ioana,
Just load the gtm file in post, and then edit the wireframe object setting Edge angle to 0 degrees. that should display your surface mesh in the 3D viewer. I hope that is the answer you were looking for. Regards Paco |
June 11, 2004, 02:10 |
Or if you want to see the mesh (to see the density at particular places or whatever) you define a plain and on render tab for this plane click the "draw lines" on.
in cfx5.7 is the surface mesh displayed from the moment you define the domain. At least it does for me )).I think. matej |
June 11, 2004, 04:27 |
thank you
Hi Paco & Matej!
Thanks a lot for your advice. It works! Have a nice day, Ioana |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? | jash | ANSYS Meshing & Geometry | 19 | July 23, 2013 18:48 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
