August 6, 2004, 17:13 |
CEL expression
Can I solve a partial diferencial equation using a cel expression?
August 7, 2004, 00:29 |
Re: CEL expression
Not really.
You can create an additional variable which will be solved as a PDE. You can eliminate either the convection or diffusion term if needed through the CCL, and then set the transport quantities as constants or variables through the CEL. This way, the solver does the work of solving the equation for you. Jeff |
August 7, 2004, 12:16 |
Re: CEL expression
Thank you Jeff.
CEL expression | vmlxb6 | CFX | 1 | March 18, 2011 06:39 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Help needed for writing CEL expression | kmgraju | CFX | 5 | September 20, 2010 18:30 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
