CEL expression
Old   August 6, 2004, 17:13
Default CEL expression
Henry
Can I solve a partial diferencial equation using a cel expression?
Old   August 7, 2004, 00:29
Default Re: CEL expression
Jeff
Not really.
You can create an additional variable which will be solved as a PDE. You can eliminate either the convection or diffusion term if needed through the CCL, and then set the transport quantities as constants or variables through the CEL. This way, the solver does the work of solving the equation for you.
Jeff
Old   August 7, 2004, 12:16
Henry
Thank you Jeff.
CEL expression vmlxb6 CFX 1 March 18, 2011 06:39
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Help needed for writing CEL expression kmgraju CFX 5 September 20, 2010 18:30
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 17:23
