Initialize Particle Transport Model
Old   August 31, 2004, 14:09
Default Initialize Particle Transport Model
Jene
I would like to apply Particle Transport Model to simulate multiphase flow problem. Since the solid particles were uniformly distributed in water initially and all the boundaries are wall, how can I set up this conditions? I mean nowhere can I set a initial number of particles in the domain without using enabling the Particle Injection on Boundary Conditions Panel.
Thanks for your input,
Best regards,
Jene
Old   September 1, 2004, 02:54
Default Re: Initialize Particle Transport Model
HK
I thought you could inject particles from those uniform locations during the calculation or even at the begging of the calculation.
HK
Old   September 1, 2004, 15:32
Sankalp
You can initialize any number of particles anywhere in the domain. If you want to initialize particles on the wall or one of the patches you can do it through command language. However, for more complex boundary conditions on particles, you need to modify user routine USRPBC. Hope it helps.
Sankalp
Old   September 1, 2004, 15:43
Default I forgot mention that I am using CFX 5.7
Jene
Thanks,
Jene
How to put melting point data of inert particle in DPM model of Fluent subhankar_bhandari Fluent UDF and Scheme Programming 1 February 5, 2018 07:08
species transport model or mixture model?HELP zhhjll FLUENT 3 March 5, 2011 15:27
How to put melting point data of inert particle in DPM model of Fluent subhankar_bhandari FLUENT 0 July 28, 2010 07:40
Species transport combustion model hari FLUENT 0 October 26, 2007 02:18
Ash particle formation with HC fuel model Bernhard Dobmeier CFX 1 August 22, 2006 10:24
