Spray drier model
Old   September 16, 2004, 01:46
Default Spray drier model
Kes
If anybody can explaing what the spray drier model means, that would be great.
Thanks
Keswani
Old   September 17, 2004, 09:59
Default Re: Spray drier model
Jeff
Assuming your talking CFX-4, the spray drier model simply attributes some moisture to each particle. As the particles travel through the domain, the moisture will be removed and the mass of the particle reduced until the particle either leaves the domain, or is reduced to it's base solid component (dry).
It is possible to use the spray drier model to evaporate liquid droplets, in which case the moisture content is 100%, and the particle will just disappear when the mass reaches nil.
Jeff
Turbulence Model and limitation to Reynolds number qascapri FLUENT 0 January 24, 2011 10:48
water spray, multhipase model??? bugra FLUENT 2 February 10, 2010 04:59
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
the role of the atomization model Jay Siemens 2 March 7, 2008 20:16
Kato-Launder model sam Main CFD Forum 13 September 21, 2006 10:15
