Vapour bubble integrity
Old   November 18, 2004, 15:30
Default Vapour bubble integrity
Matjaz Kariz
Hello! Recently I have been doing some simulation on bubble climb from the bottom of the boiling pool to the surface. I have described the bubble initial shape and volume using concentration expressions (described the location shape and volume of vapour phase with step function). I use transient type of simulation so I can evaluate the bubble rise at different timesteps. A problem occured right after the first step. The bubble tends to dissolve in water phase. In Physics/ Fluid list I have selected both phases and set Bouyant Domain model/Fluid models/ I have set homogeneous standard model, Water and vapour tested both dispersed and continuous fluid, Fluid pairs set the surface tension coefficient and surface tension model...
At the beginning the bubble is seen, but after the first step... How can I achieve to keep the bubble in one piece from the bottom to the surface? Any suggestions?
Matjaz Kariz
bubble rising problem swamysrikanth ANSYS Meshing & Geometry 3 May 31, 2016 11:09
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 08:59
Separation bubble, hypersonic compression corner ben akih CFX 3 December 10, 2006 16:33
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 00:02
