What BC should I set for door?
Old   February 18, 2005, 15:37
Default What BC should I set for door?
CFX5.7User
I am simulating airflow among several rooms, what BC should I set for a door between two rooms? I know I do not need to set any BC for the internal door. But I set the door BC anyway to make an easy calculation in Post.
Should I use an opening, static pressure=0,turbulence option: low (1%)?
Thanks in advance.
Old   February 18, 2005, 18:26
Default Re: What BC should I set for door?
Akin
Opening
Old   February 22, 2005, 13:40
CFX5.7User
Thank. But I tried opening,inlet and outlet, none of them worked in CFX 5.7 for an internal door (CFX-Pre complained). After I deleted it, everything is fine.
Old   February 23, 2005, 04:53
matej
you cannot have a boundary (like opening, or inlet) inside the domain!
If you want to monitor the variables or mass fluxes, you have to do it without the boundary conditions.
matej
Old   February 24, 2005, 14:12
CFX5.7User
Thanks. However, it would be nice if CFX allows such a "boundary" just for postprocessing purpose.
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Porous region set braket FLUENT 4 November 18, 2010 02:09
What value shall I set for the Convergence criteria? steventay CFX 7 May 14, 2010 12:44
Install problem in linux navaladi OpenFOAM Installation 11 July 17, 2008 02:24
Ibm java gcc rrr OpenFOAM Installation 2 December 30, 2005 04:18
