FORTRAN Routine - variable passing
Old   August 11, 2005, 13:23
Default FORTRAN Routine - variable passing
Malcolm
Hi
I am writing a FORTRAN routine (for use in cfx 5.7.1) and am confused about how variables are passed to it. It is similar to the example in the cfx manual "User CEL Example 1: User Defined Momentum Source" but a little more complicated.
From the user function editor I need to pass in: Temperature, y location, and z location. So in the arguments list box I have:
Argument List: [K], [m], [m]
Within the FORTRAN routine, I have it so that the lower level routine is called using:
CALL USER_NAME (NLOC,RET(1,1),ARGS(1,1),ARGS(1,2), ARGS(1,3)))
My confusion is regarding what ARGS(1,1), ARGS(1,2), ARGS(1,3) are. How does the FORTRAN routine know that I wanted ARGS's to be. (i.e. how do I pass the y and z locations rather than the x and y)
Any advice would be appreciated.
Old   August 11, 2005, 18:51
Default Re: FORTRAN Routine - variable passing
Malcolm
Never mind.
I forgot that that the variable is defined where the subroutine is initially called.
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
