October 31, 2005, 14:53 |
Symmetry Plane
Hi all,
I'm currently running simulations for an aerofoil in a wind tunnel, and to cut down on processing time, am using a symmetry plane to cut the problem in half, as it is symmetrical. My question is, when I am calculating lift from the "forces" bit in the results file, does the global y force take into account the whole of the simulation, or just the half i have modelled? Thanks, Andrew |
November 1, 2005, 08:54 |
Re: Symmetry Plane
Hi Andrew,
The solver will only give you the force on the part of the model it is simulating, i.e. half of the aerofoil. Cheers Paul |
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge | TWaung | CFX | 2 | February 16, 2010 08:11 |
Symmetry plane help! (with schematic) | Nate | Siemens | 1 | October 11, 2007 10:46 |
Symmetry plane error in solver | Santiago Orrego. | CFX | 6 | January 31, 2007 07:09 |
ICEM and symmetry plane | Roland | CFX | 3 | September 13, 2006 08:38 |
Symmetry plane and force calculation | Roland | CFX | 7 | May 31, 2006 13:34 |
