How to create airfoil structure in DesignModeler |
November 28, 2005, 17:46 |
Is there any way to create a airfoil structure using DesignModeler.I heard we can input the required parameter in excel spreadsheet first.Any tutorial on that? Please help. Any suggestion is welcome.
March 16, 2009, 13:12 |
Dongzi Wei
In the following link, you can find cooridinate of the vertices for the airfoil. Hope it can help.
March 20, 2009, 19:37 |
April 24, 2009, 05:29 |
wind rotor blade simulation
Hi, everyone:
Can I use the Turbogrid to mesh the flow field of a wind turbine blade? I know the Turbogrid and ICEM can mesh an internal flow turbomachine easily such as gas turbine and water turbine. But I'm not sure whether it can mesh an external flow rotor like wind turbine. Does anyone has some experience and give me some advice? Thank you!
sivaramakrihnaiah |
Low Speed Airfoil | Mancusi | FLUENT | 7 | April 3, 2014 06:11 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 04:36 |
[ICEM] Can’t get 2D Blayer in hex mesh to be accurate O-block around airfoil | josip76 | ANSYS Meshing & Geometry | 2 | June 4, 2011 18:03 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
