Inlets - Outles activation time
Old   December 13, 2005, 12:24
Default Inlets - Outles activation time
Chucho
Is there any way to define the time at which the inlets and outlets should be opened? Is there any way of defining a kind of algorithm that rules the opening and closing activity of inlets? any help would help, tx
Old   December 14, 2005, 02:51
Default Re: Inlets - Outles activation time
TB
why do you need that? Is it a transient simulation? Are you talking about "opening" boundary condition?
Old   December 14, 2005, 14:07
Chucho
Yes it is a transient simulation, i have inlet and oulet boundary conditions that works as fans or grilles, and what i need is to simulate the activation of this fans and the opening and closing of grilles. So is there any way to set this times?
Old   December 15, 2005, 06:09
Martin
that's pretty easy
If you want to set e.g. inletvelocity to 10 m/s at 5 s
you can write to the velocity at your inlet
step(5-Time/1[s])*0[m/s] + step(Time/1[s]-5)*10 [m/s]
step return 0 if the expression is <=0 and 1 if >0
you have to work without dimension within step, so you need Time/1[s].
bye martin
Old   December 15, 2005, 07:31
TB
Another method....Use profile boundary condition if you have some experimental data at inlet/outlet...
Old   December 20, 2005, 11:24
Chucho
When I look into the inlet properties the Profile Boundary option is disabled. How can I activate this option so I can enter experimental inlet data?
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
