How to switch of Timestepping Information
Old   December 9, 2005, 11:18
Default How to switch of Timestepping Information
TobiasZ
I have just installed CFX 10.0 and have run the same a transient simulation def.file as used before in v5.7.1 from scratch. An additional information appears now before each time step in the CFX-Solver Output File, telling me the "Timestepping Information" for the RMS Courant Number. I know this is needed for the Adaptive Time Step option which I, however, do not use. Does anybody know, if this RMS Courant Number calculation and the output in the output file can be switched off?
Thanks Tobias
Old   December 11, 2005, 16:21
Default Re: How to switch of Timestepping Information
What is the point of turning it off? If you don't need the information then ignore it.
Old   December 12, 2005, 02:57
Default Re: How to switch off Timestepping Information
TobiasZ
Hello Glenn,
Thanks for replying. Well, this information did not appear in the older Versions (e.g. v5.7.1) and I am wondering, if this is now generally shown because of the additionally included time adaption option, or if this information only appears in the ouput file because of a mistake I've possibly made in my parameter settings.
Regards
TobiasZ
Old   December 12, 2005, 04:41
James Date
The information is there to help you! If you are conducting the transient simulation correctly, you should be satisfying the courant requirements for transient simulation even in CFX-5.7.1. At least this output saves you having to calculate the courant number manually or in CFX-post.
James
Old   December 12, 2005, 05:47
TobiasZ
Understanding your comments correctly, the plot of the Courant number in the output file is now a fixed part in v10.0? If it's so, thanks for your help and advice. TobiasZ
Old   December 12, 2005, 08:47
James Date
Yeah, its just a new feature which they have added. Before you had to calculate this manulally.
Representing controlDict information using OpenFOAM classes sanatan OpenFOAM Programming & Development 4 February 28, 2012 06:46
interchanging face information with cell information/ radiation flux UDF ximik FLUENT 1 May 4, 2011 16:34
information from saved data files:Unsteady flow Atul FLUENT 5 July 27, 2008 20:05
Information - SES Giovanni Main CFD Forum 0 March 2, 2004 13:17
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
