Modelling Superheater tubes
Old   February 18, 2006, 04:38
Default Modelling Superheater tubes
Mohammed Zuber
Hii friends, i ahve to model superheater tube bundles in a steam furnace considcering the radiation view factors also.i already have the combustion analysis of flue gases inside the furnace. i am unable to conceptualize the design of the superheaters inside the furnace. i need to design atleast 4 tubes to study the effect of high temp on the steam flow. How shal i incorporate the tubes inside the furnace model in Ansys ICEM, also during analysis using CFX 5.7 i am not able to understand how to consider the domain and sub domains in the model.
Kindly help
Old   February 20, 2006, 04:02
Default Re: Modelling Superheater tubes
Chirag Jayswal
Create tubes using cylindrical surfaces without considering thickness. While specifying mesh parameters, tick on "internal wall" & "split wall". Create two different bodies, one representing fluid in furnace & other representing fluid in tubes.
Thus you should be able to model & mesh your domains.
Only doubt I have is, how will you create two different domains in CFX representing two different fluids?
Kind regards, Chirag
Old   February 20, 2006, 04:33
Tom
two different fluid??!!
Modelling unsteady 2D aerofoil drag xlxc34 Main CFD Forum 0 June 24, 2011 04:42
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
Unsteady modelling technique? Carlos FLUENT 0 September 26, 2008 11:37
superheater physics zubair CFX 3 June 24, 2006 06:07
Computational Modelling of Vortex Separators May Lim Main CFD Forum 6 November 13, 1998 12:36
