February 23, 2012, 17:05 |
#21 |
Rep Power: 143 |
You can define pressure drop any way you like, what ever is important for your application. But most people use the pressure drop from inlet to outlet, probably using the areaAve() function.
February 24, 2012, 01:08 |
#22 |
arjun
Rep Power: 14 |
thanks a lot.
February 24, 2012, 02:14 |
#23 |
Safia
Rep Power: 15 |
Glenn,, thanks a lot
February 24, 2012, 05:16 |
#24 |
arjun
Rep Power: 14 |
I measured the area avg pressure at inlet it gives me some value say 500 Pa. and at outlet it gives O Pa. because of i have used outlet pressure Boundary condition to 1 atm (0 gauge). then 500 is my pressure drop. is it write way? |
February 24, 2012, 06:10 |
#25 |
Rep Power: 143 |
Yes, that's right. You have a 500Pa pressure drop across your device.
Tangential Component of Gradient??? | Kelvin_mk | OpenFOAM | 0 | June 29, 2011 15:30 |
Cylindrical coordinate system - tangential velocity | alessio.nz | OpenFOAM | 2 | December 7, 2010 05:07 |
Cyclone Tangential Velocity ... | Abdul | FLUENT | 2 | August 13, 2008 00:07 |
Multiple Inlets | Charlie V | FLUENT | 0 | May 28, 2001 02:29 |
create Volume with inlets | Roman Bohnes | FLUENT | 10 | December 6, 1999 04:43 |
