ICEM CFD 5.1 problem with tetra count
Old   March 13, 2006, 08:21
Default ICEM CFD 5.1 problem with tetra count
Baskaran
We are trying to create TETRA mesh using ICEM-CFD 5.1, in Windows XP platform. When the TETRA count exceeds, 41,000,000, ICEM-CFD terminates with message "Assertion failed: cells !=0, file cell_base.C, line 1065".
When we try the same in Linux (RH Enterprise version 3.0), we could able to go upto 44,000,000 TETRAs, and it terminated with message, "Abort status 134 Application is finished Error: tetra didn't create ./tetra_mesh.uns"
can somebody help to overcome this issue, in any of the above mentioned platforms??
Old   March 13, 2006, 09:01
Default Re: ICEM CFD 5.1 problem with tetra count
myron
The memory per process on a 32-bit machine is 2 GB. You'll see slight differences on Windows vs Linux - due to differences in the OS. You may be able to subdivide to that large number of cells, but you'll never be able to do anything with the mesh - again due to memory limitations. You'll need to go to 64-bit machines.
Old   March 13, 2006, 12:59
TobiasZ
wao, this is really a high amount of elements. Are you sure you have enough capacity for doing the calculations?
Need help icem cfd kakhtar ANSYS Meshing & Geometry 25 January 31, 2017 01:09
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
[ICEM] Problem while improting Solidworks Part file or Acis File into ICEM CFD venki1130 ANSYS Meshing & Geometry 0 October 13, 2011 13:04
ANSYS ICEM CFD: lsdyna input file creation problem Evan CFX 0 June 15, 2006 13:12
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
