linear solver failure when using SST model
Old   March 21, 2006, 06:25
Default linear solver failure when using SST model
fanzhong Meng
I do a quasi-3D airfoil simlation, and I had generate one element(2mm) 3D grid. when i use SST model to calculate, I always get the follow error message after several steps of iteration.
ERROR #004100018 has occurred in subroutine FINMES.
Message: | Fatal overflow in linear solver. I found that the "wallscale" variable can not converge. but other variable, such as velocity mass and k and W, can converge. I don't know why. Does it have something with the grid quality? The largest width-height ratio of my gird may be 400. That is because I have made a very fine grid near the wall (0.04mm),so this will contribute to large width-height ratio in some position.
can anyone give me some suggestion? thanks a lot .
Old   March 21, 2006, 11:22
Default Re: linear solver failure when using SST model
Robin
Wallscale is a simple diffusion equation. If it is failing, it is probably due to poor mesh. Large aspect ratio's should not be a problem (and 400 isn't very high), but if they are the problem would go away by running double precision. I recommend opening your model in Post and looking for elements with very small edge angles.
-Robin
Old   March 21, 2006, 11:43
fanzhong Meng
Hi, Robin
Thank you for give me the recommendation. What I want to say is that my mesh was generated by Gambit2.1. And I have checked the quality of the mesh. except for the aspect ratio, the equiangle skew of the mesh is smaller than 0.1. So I think the quality of the mesh should be very good,except for the large width-length ratio.(it is not aspect ratio,maybe I didn't describe clearly before.)That is to say, some grid should be very long and very thin, but the angle of close to 90 degree.
Old   March 21, 2006, 12:21
fanzhong Meng
Hi Robin
Just now I have changed the aspect ratio of my mesh. Because I don't know the original value of aspect ratio exactly, so what I can show you is that I decreased the aspect ratio 8 times. and than it can work. I think the problem should be contribute to the poor aspect ratio.
Could you tell the normal value of aspect ratio?
-Fanzhong Meng
Old   March 21, 2006, 20:16
TB
Hi Robin,
I found your comment a bit confusing. I remember reading somewhere in the manual that solver may have problem if edge length ratio > 100.
Is 400 far beyond the limit specified in manual? Is there any significant improvement in Version 10 that allow edge length ratio to go beyond 100?
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
desperate Fatal overflow in linear solver - transient kingjewel1 CFX 9 January 5, 2010 13:53
YPlus Values and SST Model Jenny CFX 1 June 22, 2008 18:47
Convergence issue in SST for Porous model Raj CFX 0 May 2, 2008 02:43
SST model help please! Sheila Siemens 2 September 6, 2004 22:39
