Home > Forums > CFX
Multiphase reaction Solver Error
Old   April 4, 2006, 06:59
Default Multiphase reaction Solver Error
hagupta
My problem consists of a "Reacting Mixture(with 4 gases)",a solid (MultiPhase-Eulerian) Out of these, the solid and a gas are formed after the reaction.
I am finding it really difficult trying to obtain the results.
I get this error and the run stops. http://tp-txdp4281.content-type.com/...ages/Error.jpg
For all the 4 gases and the solid, I have entered the Cp values as a function(User function) of temp. These Cp values, ref entropy, ref enthalpy have been taken from the NASA thermobuild.
As you can see in the above link, I have tried increasing the Newton Iteration Limit to 200, but of no avail. I have also increased the pressure limits for each gas and the solid.
How do I debug this?
Old   April 4, 2006, 09:14
Default Re: Multiphase reaction Solver Error
opaque
Dear Hagupta,
Have you tried the same simulation with constant properties already provided?
Either your properties are not thermodynamically consistent among themselves? Your time tstep may be too large...
You may need to talk to CFX help desk..
Good luck, Opaque..
Old   April 4, 2006, 10:11
hagupta
Thank you, Opaque
Only 2 of the materials that I use are predefined in CFX. So, I have not yet tried the simulation with constant properties already provided.
1) So, should I try the simulation with 3 user materials and 2 CFX materials OR try a similar reaction (1 solid and 4 gases) taking all 5 CFX materials?
2) The auto timestep value was around 2.5e-5. The least timestep I have tried is 1e-5. Should I try reducing this to 1e-7 or still lower?
If the above 2 steps do not lead me to the solution, I think I will talk to the CFX help desk.
Old   April 8, 2006, 09:43
hagupta
I tried with reduced timesteps the following 2 runs:
1) Single Phase with const prop. After several iterations(much more than what it used to be earlier) the solver crashed with "Floating point exception" error. Just before this error, I got "The Mach number exceeds....." error.
2) Multiphase with the value of "Minimum volume fraction for Mixture/Solid fluid pair set to the minimum possible(1e-15). This too crashed with "floating point exception-division by zero" error.
I was searching for the possible causes for this error and found a coarse mesh as one of the possible causes. Both of the above 2 setups had the same very coarse mesh. I have been using the coarse mesh to save time since I run it on a single processor.
So, how do I proceed further? Interpolate the results from the last saved .bak file onto a finer mesh and continue?
Regards, hagupta
Thread Tools
Trackbacks are On
Error in CFX Solver Leuchte CFX 5 November 6, 2010 07:12
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
groovyBC sega OpenFOAM Running, Solving & CFD 12 February 17, 2010 09:30
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
