April 7, 2006, 10:19 |
dye simulation
Hi everybody,
I am trying to do a simulation of dye in water channel released from a designated area, does anyone know how to do it in CFX 10. I could do particle tracing in transient run. But what I want is the exact modeling which will look like movement of "volume" not "particles" in steady flow. Any help would be very much appreciated. Thanks alot, Mike |
April 7, 2006, 13:40 |
Re: dye simulation
Hi, Mike
I guesss you want to do a transient tracer dye simulation. If that's you want, just go to the ANSYS CFX forum, and search 'tracer'. You will find some posts descibing every details of tracer simulation. By the way, it seems that you did some particle tracer simulation in steady flow. Are there special reasons to do that? Regards! James |
April 7, 2006, 14:22 |
Re: dye simulation
Hi James,
Thanks alot for your help. Actually what I want is the following. I have some experimental visualization of dye patterns for some period of time in steady state flow condition . And I want to compare my simulation directly with that experiments. What I know with particle tracer, you can get particle motions in flow. However I want volume movement like dye markers. That is the reason, I am looking for that kind of simulation. Thanks again, Mike |
April 9, 2006, 18:36 |
Re: dye simulation
If the dye just moves with the fluid I think you will find the additional variable approach better. This uses a Eularian approach rather than Lagrangian and has vastly less computational load than particle tracking as there is coupling of the marker dye to the mass/momentum/heat equations. It's been a while since I've done one, but I think you declare an additional variable and define it to convect with the flow and you define a diffusivity constant (or just give it 1e-20 if you want it just to convect around with the flow). Regards, Glenn Horrocks |
April 9, 2006, 18:59 |
Re: dye simulation
Personally I think 'computational load' may be just one small issue for choosing Eulerian approach or lagrangian approach. The two approaches have fundamental differences. Lagrangian approach may be good for modelling particle behaviour. For dye simulation, I doubt if good results can be obtained by using lagrangian approach. Regards! James |
April 10, 2006, 05:03 |
Re: dye simulation
The additional variable approach is probably the best way to do this. I think the CFX manual gives an example of this or at least talks about it under the Additional Variable section of the manual.
April 10, 2006, 10:57 |
Re: dye simulation
Hi Guys, Thanks alot for your help. I will try to use additinal varible as you suggested instead of particle tracer approach. I think that is what I want.
Why my simulation not agree with the wind tunnel experiment | zhaowei | CFX | 4 | July 11, 2015 03:36 |
Axial fan simulation in UG/NX 7.5 | fan123 | Main CFD Forum | 2 | April 23, 2011 08:22 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 08:18 |
velocity profile export from a simulation onto another | sudhirlv | STAR-CCM+ | 1 | September 12, 2010 18:57 |
