subroutine FORTRAN // CFX in Spain
Old   May 23, 2006, 06:12
Default subroutine FORTRAN // CFX in Spain
spain
Hi! I've modified the subroutine used in the tutorial 17 (air conditioning) for my own sensor. If there is: H2 Ideal Gas.Mass Fraction > CLIM1 = 0.003 then I want my input of H2 to be closed.
The velocity Y of the input will be: H2_ON*10 [m s^-1]
CSENSOR = probe(Mixture.H2 Ideal Gas.Mass Fraction)@Detector,
where Detector is a Monitor Point.
Could somebody check if my routine is right?
#include "cfx5ext.h" dllexport(h2_on)
SUBROUTINE H2_ON (
& NLOC, NRET, NARG, RET, ARGS, CRESLT, CZ,DZ,IZ,LZ,RZ )
CD Control an input H2 by a sensor
#include "parallel_partitioning.h"
INTEGER NLOC,NARG,NRET
CHARACTER CRESLT*(*)
REAL ARGS(NLOC,NARG), RET(NLOC,NRET)
INTEGER IZ(*)
CHARACTER CZ(*)*(1)
DOUBLE PRECISION DZ(*)
LOGICAL LZ(*)
REAL RZ(*)
CHARACTER*20 ROUTIN
PARAMETER(ROUTIN='HEAT_SOURCE')
INTEGER ILOC, NCLOOP
REAL CSENSOR, CLIM1, VALUE
C initialize H2 input to be on
DATA VALUE/1.0/
C initialize the variable that keeps track of the last time step
DATA NCLOOPLAST/-1/
SAVE VALUE
C Initialise RET() to zero.
CALL SET_A_0( RET, NLOC*NRET )
CSENSOR = ARGS(1,1)
CLIM1 = ARGS(1,2)
NCLOOP = INT(ARGS(1,3)+0.1)
IF (NCLOOP .EQ. 1) THEN
C At the start of a new timestep. It is time to re-assess whether to turn on or off the H2 input.
IF (CSENSOR .GT. CLIM1) THEN
C Turn off H2 input
VALUE = 0.0
ELSE
VALUE = 1.0
ENDIF
ENDIF
DO ILOC = 1, NLOC
RET(ILOC,1) = VALUE
ENDDO
C Set success flag.
CRESLT = 'GOOD'
END
Does anybody know where I can find someone who knows how to use Ansys-CFX in Spain?? Thank you very much!!!
Comparison between C/C++ and Fortran? rick Main CFD Forum 45 September 6, 2011 00:52
fortran subroutine to read mesh HaKu Main CFD Forum 0 May 23, 2011 12:36
error on CFX compile fortran subroutine billpeace CFX 0 May 18, 2006 04:44
how to use USER FORTRAN with CFX cfd_99 Main CFD Forum 1 June 4, 1999 05:42
CFX User Subroutine Archive David Creech Main CFD Forum 0 March 17, 1999 12:41
