CD calculation
Old   May 8, 2006, 12:39
Default CD calculation
Alireza
I'm calculating the drag past 2D circular and elliptical cylinders. I'm not very sure about the reference values I'm using. As for the frontal area, I'm using the diameter of the cylinder since the depth is unity. I'm using the diameter also for the length. For the velocity I'm using the free stream velocity. Are these values ok?
Alireza
Old   May 9, 2006, 08:52
Default Re: CD calculation
ms
If you are using CFX, there must be a 3rd dimensional distance as we dont have truely 3d solutions. So why can you not use the actual frontal area?
free stream velocity is fine
Transfer output data as input for second calculation mannobot Main CFD Forum 3 December 7, 2018 09:37
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Defining output as input for second calculation mannobot FLUENT 1 June 2, 2010 04:20
Warning 097- AB Siemens 6 November 15, 2004 04:41
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 08:19
