About create new material
Old   May 18, 2006, 04:04
Default About create new material
jasonchang
When i simulate fluid flow,I do it succesfully by use water as the material,but use a material created by myself, Error ,as below: | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | NAME_MOD: Error finding variable "DRHODP_T" The material I create as follow: LIBRARY:
MATERIAL: Aluminium Liquid
Coord Frame = Coord 0
Material Description = Aluminium Liqid is used for foundry simulation
Material Group = Constant Property Liquids
Option = Pure Substance
Thermodynamic State = Liquid
PROPERTIES:
Option = General Material
DYNAMIC VISCOSITY:
Dynamic Viscosity = 0.0012[Pa s]
Option = Value
END
EQUATION OF STATE:
Density = 2.371 [g cm^-3]
Molar Mass = 27 [kg kmol^-1]
Option = Value
END
SPECIFIC HEAT CAPACITY:
Option = Value
Reference Pressure = 1 [atm]
Reference Temperature = 700 [C]
Specific Heat Capacity = 950 [J g^-1 K^-1]
Specific Heat Type = Constant Volume
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 217.7 [W m^-1 K^-1]
END
END
END END
Help me!Thank you in advance!
Old   May 18, 2006, 08:22
Default Re: About create new material
chayriss
Dear jasong, I think this is not a ""Material Group = Constant Property Liquids""" you can try with Material Group = user , that is the first mixtake i see, I not sure, but I hoppe this can help you
best regards
chayriss
Old   May 18, 2006, 09:30
opaque
Dear Jason,
I notice that you are setting the Specific Heat Capacity at Constant Volume instead of at constant pressure.. To convert from Constant Volume to Constant Pressure you need the derivative of density respect to pressure at constant temperature.. Perhaps the conversion has a bug..
Try setting the Cp instead..
Good luck,
Opaque..
Old   May 18, 2006, 21:07
jasonchang
Dear chayriss ,opaque:
I modify the setting just as what you suggest,it works well.Thank you.
By the way,how to use ansys cfx10.0 to simulate solidification and fluid flow?I would appreciate if anyone can give me some advice.
It was said that just CEL can set up the modelling,Is it true?I am not good at FORTRAN language. Thanks in advance.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 09:03
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
