storing variable value at a particular point
Old   June 19, 2006, 05:41
Default storing variable value at a particular point
prabhu
Hi, How can we store a variable value for a particular point in the domain, at different time steps? The CFX-Pre stores the variable values for all points.
Thanks
Old   June 19, 2006, 07:14
Default Re: storing variable value at a particular point
Joe
User fortran. Create your own variables. Read the "Memory management" section of the manual.
Old   June 19, 2006, 08:37
Robin
What exactly are you trying to do?
Old   June 19, 2006, 23:33
prabhu
I have to store the values of pressure and velocity, only at a point (monitor point) on the axis at the inlet of a nozzle for each timestep. So that i can plot the variables with respect to time. I think that values at monitor points(created) will not be stored for post processing. Values are stored for the whole domain and it amounts to lot of memory.
Old   June 20, 2006, 19:50
Robin
Values at monitor points are stored to the MON file at every iteration. At the end of the run, the mon file is embedded into the res file (which is in fact an archive). When you open the RES file in the Solver Manager, it plots the contents of the MON file.
So... create your monitor point and monitor the data you are interested in. After the run has finished, right click on the plot in the Solver Manager and you can output your data to a .csv file.
Just keep in mind that if you do not include the trn files and you see something interesting in the monitor data, you will not be able to go back and view the results at those timesteps. At the very least, I recommend calculating transient statistics.
Regards, Robin
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 01:40
Problems with additional variable Krishna Premi CFX 1 October 29, 2007 08:19
Multi_component Vs Additional Variable Anurag CFX 2 February 4, 2005 16:45
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
