Source terms in local coordinate frames
Old   August 24, 2006, 21:00
Default Source terms in local coordinate frames
CF
Hi!
I have two subdomains where I need to apply momentum source terms in the tangential direction. These source terms are dependent on the radius and theta values in the respective subdomains.
I have defined two new cartesian coordinate frames and applied these coordinate frames to the subdomains. Then using CEL, I have defined the source terms which contain r and theta.
Does CFX calculate r and theta for each subdomain separately? It doesn't seem so, coz my source terms are calculated fine for one subdomain, but not for the other!
Help!
Old   August 25, 2006, 10:15
Default Re: Source terms in local coordinate frames
Robin
Do you have a local coordinate system for each subdomain?
Old   August 29, 2006, 02:30
Amod Kumar
Dear CF,
The CFX tutorial says source term = source coeff (U - Uspec, etc. Could you please guide me how to calculate source coefficient, Uspec, Vspec, and Wspec for an axial flow fan? I am modeling a fan in completelt enclosed cabin as momentum source.
Thanks a lot in advance,
Amod Kumar
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
UDF Source terms not producing expected results... Emmanuel Resch FLUENT 0 July 31, 2008 14:55
Point implicit treatment of k-e source terms andy Main CFD Forum 5 June 9, 2006 11:03
