October 12, 2006, 23:15 |
Difficult to Converge in Natural Convection
I simulated a hot solid object in complex inclosure tank .The object generated the heat and heat transfer through convection to the gas and conduction in bounded tank shell. I used large solid time scale and monitored imbalance in the gas H-energy and solid T-energy. The imbalance approached to 0, but the RMS residual could not be converged. I changed the simulate type from steady state to transient, but it will take a long time to approach steady state temperature. Could you give me a tip or some advice about this problem? Thank you very much. |
October 15, 2006, 18:01 |
Re: Difficult to Converge in Natural Convection
What Rayliegh number is the device operating at? If the Rayliegh number is high it is possible that no steady state solution exists and the only accurate way to go is transient. Glenn Horrocks |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
Natural Convection Problem - Helium | marzoa | STAR-CCM+ | 0 | April 18, 2011 14:12 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 04:58 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Approximate Mixing due to Natural Convection | Greg Perkins | Main CFD Forum | 0 | February 12, 2003 18:43 |
