High Aspect Ratio elements
Old   November 23, 2006, 16:34
Default High Aspect Ratio elements
Flavio
Hi all.
I'm having problems regarding convergence. I think this is due to high aspect ratio elements because this is the only warning message the program returns me.
First. I'm simulating a pump stage, operating several modifies to the structure. The first simulations gave no convergence problems: maximum 15 high aspect ratio elements. The latter simulations shows around 40 High Aspect Ratio elements. I don't understand why, because the meshing parameters are exactly the same, and the High Aspect Ratio elements occurs in points of the pump stage that have not been modified at all. So, i can't get the reason because of this occurs.
Second. I don't know how to manipulate the mesh paramters in order to eliminate (or reduce) the High Aspect Ratio elements. This because they are created on narrow appendix of the fluid volume.
Thanks anyone would like to help.
Flavio
Old   November 24, 2006, 09:33
Default Re: High Aspect Ratio elements
alex
what's your mesher? ICEM CFD ? what kind of mesh (hex or tetra-prism). If u are using ICEM CFD, try yo use quality mesh functionnality to find bad meshes.
good luck
Old   November 24, 2006, 12:01
Flavio
Cfx-Mesh. Tethraedrons and inflation wedges.
Thanks.
[ICEM] Mesh along axis for a wedge gives elements with extreme aspect ratio sangrampp ANSYS Meshing & Geometry 0 November 17, 2010 06:57
re: Viewing High aspect ratio elements in CFX post MMG CFX 1 December 13, 2006 06:26
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
high aspect ratio elements Olivier CFX 5 April 3, 2003 06:55
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
