Free rotation of a swirler in a CC
Old   October 26, 2006, 12:19
Default Free rotation of a swirler in a CC
Maria Angelica
Hello!! I will start the simulation of a Combustion Chamber! It has a swriler for the inlet of the stechiometric air in the liner. I wonder how to set the motion in the swirler depending on the inlet velocity of the flow. Usually we can assign the rotation of the rotor, etc in other cases, but in this case, I want it to react to the forces of the flow!!
Does somebody know if this is possible! Any suggestions please!!!
Ma Angelica
Old   October 27, 2006, 09:15
Default Re: Free rotation of a swirler in a CC
Robin
Hi Angelica,
If it is reacting to a torque on the swirler blades, write an expression for rotational velocity as a function of the blade torque. The general expression structure for torque is:
[<Fluid>.]torque_[<Axis>[_<Coord Frame>] ]()@<Location>
Say the blade region is called 'swirler blade', torque about the global x axis would be:
torque_x()@swirler blade
I would recommend putting an upper limit on the rotation rate to prevent it from becoming too high. If you write an expression for the swirler speed, say 'RPM Swirler', I would enter it in the rotational velocity parameter within a min function, i.e.:
min(RPM Swirler, Max RPM)
When using CFX, just keep in mind that just about anywhere you enter a value, you can also use an expression and CEL is evaluated on the fly.
Regards,
Robin
Old   October 27, 2006, 09:16
Robin
Looks like the HTML formatting screwed up the expression structure I listed at the top of my message. Just look in the CFX Post documentation for this. The torque expression is correct.
Old   October 28, 2006, 09:44
María Angélica
Thank you Robin!
I will try that!
Best Regards,
Ma Angelica
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
Can Flow-3D plot the free surface area in Iso-surface or colour variable? therockyy FLOW-3D 1 June 20, 2010 19:36
Rotation of a 3d rigid body through its free end M-Ray FLUENT 0 May 20, 2008 09:56
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 06:27
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 15:56
