Is it multiphase problem?
Old   November 4, 2006, 02:12
Default Is it multiphase problem?
Se-Hee
I'm trying to solve a conjugate heat transfer (CHT) problem in CFX-10. The geometric setup is as follows:
There is a hollow iron sphere in the air. The temperature of iron sphere is 100 Celsius and the sphere is filled with an insulating gas, SF6. Here, I'd like to simulate the heat transfer flow characteristics in all three parts: air, iron, and SF6.
In CFX, I cannot setup two different gas domains: air and SF6. Is it multiphase problem? I highly appreciate if you can provide me any hints and comments for solving this problem.
Thanks, Se-Hee
Old   November 4, 2006, 04:25
Default Re: Is it multiphase problem?
hdj
You can setup two domain with different physics. Set variable "CFX5_NO_CONSTANT_PHYSICS" to a nonzero value. For more information please search this forum.
hdj
Complex multiphase melting problem leff CFX 12 March 18, 2014 16:46
Mass conservation in multiphase problem cna FLUENT 6 April 4, 2010 10:16
UDF problem in multiphase model Amir Khodabandeh FLUENT 1 March 13, 2009 08:43
Problem of B.C. in Eulerian multiphase model Derek Jing FLUENT 0 May 12, 2002 11:52
CF4 - need advice on setting up multiphase problem Brett Towler CFX 2 August 18, 2000 16:38
