how to set the boundary conditions correctly? (cube with 10,000 W losses) |
January 25, 2021, 01:14 |
Liza
Rep Power: 5 |
I’m trying to solve this problem: Cube (steel) 1m^3 with 10 000W loss. I want to see how this cube heat up. I don’t understand how to do boundary conditions correctly. I set cube as subdomain with source 10 000 [W m^3]. If I set air around this cube with “opening” temperature is too high. If I set “inlet” and “outlet” with Static Pressure 1 [Pa] and 0 [Pa] then temperature is closer to real temp., but still high. I don’t understand what should i do to Ansys to understand me. Thank you |
January 25, 2021, 04:54 |
Rep Power: 143 |
This is not a CFD problem. It is just a heat transfer problem, so you don't need any fluid domains. Just set the cube as a solid domain and apply 10kW heat loss on the outer boundary.
But I don't see why you want to model this at all. There are analytical solutions for the temperature versus time for this case, or if you just want the average temperature it simplifies to a single equation. So no need to model anything.
January 25, 2021, 07:13 |
Liza
Rep Power: 5 |
When I’m doing just cube and just loss there is like 17 000K temperature. That’s unreal.
I’m modelling that just to understand how it works in Ansys. |
January 26, 2021, 17:10 |
Rep Power: 143 |
The high temperature could be either:
Numerical Error - in other words you are not solving the equations accurately. Usually this means you just need to converge tighter. So run the simulation for more time steps. This is very common in conjugate heat transfer simulations (like what you propose) as the solid time scales are just much slower than the heat transfer time scales, so getting the heat transfer to converge using default settings is tricky. Usually we add imbalances as a convergence criteria for CHT simulations to mitigate this. Physical Error - The physical setup of your simulation is wrong. Are you sure a 10kW heat load is correct? Are you sure the material properties are correct?
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
